Announce: Interface to RTEMS symbol table + C expressions
Till Straumann
strauman at SLAC.Stanford.EDU
Wed Jan 30 21:28:22 UTC 2002
Hi All.
I finally wrote this utility I always found missing in RTEMS
(hope I didn't reinvent the wheel).
It reads the symbol table from an ELF file and adds a
C-expression parser + lookup utilities (including regexp
pattern searching).
An example session (run on RTEMS target) looks like this:
I first search for the 'printf' and 'rtems_panic' routines
and then subsequently call them from a C-style expression.
I need to iron out a few wrinkles, then it'll become available.
Mostly, I have problems getting libreadline to work...
Cheers
-- Till
Eric, this could probably be integrated with IOCsh...
Cexpr>
Cexpr>
Cexpr>lkup("^print.*")
001415c[1348] FUNC : print_filename
008b0a0[ 20] FUNC : printable
0014104[ 88] FUNC : printable_part
008ffc4[ 172] FUNC : printf
0030cb0[ 228] FUNC : printk
0000000 (0)
Cexpr>
Cexpr>lkup("panic$")
002569c[ 60] FUNC : BSP_panic
005fa18[ 136] FUNC : rtems_panic
0000000 (0)
Cexpr>
Cexpr>(0xcafe && printf("\nprintk: %08x\n",printk)) || rtems_panic("no
panic")
printk: 00030cb0
0000001 (1)
Cexpr>
