[PATCH] Forwarding of UDP broadcasts
Vyacheslav V. Burdjanadze
wr at zelax.ru
Wed Jul 10 18:15:35 UTC 2002
Hi guys. I've recently implemented forwarding of UDP broadcasts to
enable browsing MS Network through RTEMS
routers. I attached the patch of libnetworking/netinet/udp_usrreq.c to
rtems-4.5.0. Although code isn't compilable
right after patching (we used heavily patched RTEMS networking code to
fit our needs) you may fix it for 10-15 minutes :). The actual code is
wrapped by FORWARD_PROTOCOL #define's . You can enable/disable
forwarding of udp packets with specified destanation port. I tested it
and it seems to work (I able to browse MS Network through two RTEMS
routers) and it not leaked. I post it for those who working on router
software. Any questions or comments are welcome.
- " Why do you call this software 'beta' ? "
- " Cuz it beta than nothin' ! "
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20020710/ef275bca/attachment.ksh>
