network initialization hangs
Sachin K sachin at dexceldesigns.com
Tue Jul 16 14:19:16 UTC 2002
Hi Pete,
thanx for that information.
i have one more ethernet card D-Link DFE583- Tx and in Network supplement
document, it says that
D-Link DFE500-Tx card uses DEC chip.
my question is
1) can i use D-Link DFE583- Tx card, whether the dec21140 driver supports
this n/w card ??
2) the RTL8139 card which i have is a built-in card, that means if the above
mentioned card, if i can use, i have to use it as an additional card.
in that case what information i have to give in bsp.h file to tell the
driver to access this D-Link DFE583- Tx  network card ?
TIA,
Sachin.K
----- Original Message -----
To: "Sachin K" <sachin at dexceldesigns.com>
Sent: Tuesday, July 16, 2002 6:15 PM
Subject: Re: network initialization hangs
> Hi Sachin,
>    The problem is that you don't have a driver for your network card.
> The things you tried are for 3com 3c509, DEC Tulip, Western Digital and
> NE2000 cards respectively. Probably you will have to write the driver,
> unless someone else already has and is willing to share.
> Pete.
> Sachin K wrote:
> > Hi,
> > from past 3 days i'm experimenting with network driver and bsp settings.
> > i have installed pc386 BSP on RedHat Linux 7.2
> > i'm trying to execute ntpdemo provided in netdemos-4.5.0 .
> > when i boot with ntpdemo.exe my pc hangs at
> > "rtems_bsdnet_initialize_network ();" routine .
> > i have tried the following bsp.h settings.
> > #define BSP_3C509_NETWORK_DRIVER_NAME           "ep0"
> > #define BSP_3C509_NETWORK_DRIVER_ATTACH
rtems_3c509_driver_attach
> > result : fail to find board
> > #if 0
> > #define RTEMS_BSP_NETWORK_DRIVER_NAME           "dc1"
> > #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_dec21140_driver_attach
> > #endif
> > result : DEC PCI not found !
> > #if 1
> > #define RTEMS_BSP_NETWORK_DRIVER_NAME           "wd1"
> > #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_wd_driver_attach
> > #endif
> > result : program hangs in "rtems_bsdnet_initialize_network ();" routine.
> > #define BSP_NE2000_NETWORK_DRIVER_NAME          "ne0"
> > #define BSP_NE2000_NETWORK_DRIVER_ATTACH        rtems_ne_driver_attach
> > result: program hangs in "rtems_bsdnet_initialize_network ();" routine.
> > PS : i have RealTek network card "RTL 8139 "
> > can anyone tell me whatz happening ??
> > Thanks In Advance
> > Sachin.K
> > Dexcel Electronics Designs (P) Ltd., Bangalore, India
> D. Peter Siddons
> National Synchrotron Light Source, Bldg. 725D
> Brookhaven National Laboratory
> Upton
> New York 11973
> Email: siddons at bnl.gov
