i386-rtems-gdb problem???
Naster rtemswq at yahoo.com.cn
Wed Jul 24 08:04:27 UTC 2002
Hello all,
I have installed RTEMS and gdb on Redhat Linux 7.2 for
pc386 ,Now I try to connect to the target pc386 via
the i386-rtems-gdb (connected via Ethernet).
I start the debugger and then type "setrpcmode sun",
"setdaemontype rdbg" "target rtems ...", while the
debugger does not know all these commands,"Undefined
command:..." error received.
I have done as below:
download source code binutils-2.9.5.0 gcc-2.95.2
rtems-4.5.0 from oarcorp and install by cstart.pdf
cd gdb-5.0/
cat ../../archive/gdb-5.0-rtems-20010314.diff | patch
-p1
find .-name "*.rej" -print (find nothing)
cd ..
mkdir b-gdb5.0
cd b-gdb5.0
../gdb-5.0/configure --target=i386-rtems
--prefix=/usr/local/rtems
make all
make info
make install(successed)
Could anybody help me on this issue?
Thanks!
                          David wu
_________________________________________________________
Do You Yahoo!?
体坛明星啸聚缤纷赛场 精彩时刻尽在雅虎体育
http://cn.sports.yahoo.com/
