Regression test question
Chris Johns cjohns at cybertec.com.au
Mon Jul 22 23:18:34 UTC 2002
Jay Monkman wrote:
> Should ID's, such as semaphore or task IDs, in the sp?? tests match
> the sample output? For example, sp12's expected output shows:
>      TA1 - rtems_semaphore_ident - smid => 18010002
> But, I get:
>      TA1 - rtems_semaphore_ident - smid => 1801000a
> Is that expected or an indication of a problem? Some of them match,
> others differ by 5-10. If I run the tests in a simulator, they differ
> some, but tend to be closer to the expected output.
> I don't think it's an indication of a problem, but want to make sure.
Depends on the BSP. You may have a driver that initialises and comsumes
some resources and so makes the numbers you see different.
 Chris Johns, cjohns at cybertec.com.au
