Run-time selection of pc386 BSP console
Angelo Fraietta
angelo_f at bigpond.com
Thu Jul 11 22:41:38 UTC 2002
A compile time directive to determine whether the auto detect should
take place would be better. I am using the 386dx bsp in my embedded
system and don't want my serial ports taken away from me if there is no
video adapter.
Eric Norum wrote:
> On Thursday, July 11, 2002, at 03:20 PM, Chris Caudle wrote:
>>> Do others think that this is a good idea?
>> Yes, but I thought I remembered a compile time option to set console
>> to serial
>> instead of video. I haven't had to change any console settings in a
>> long
>> time, so I don't remember if that still works.
>> I don't have easy access to a machine with current RTEMS source at this
>> minute, but in 4.0 there were some places you could change the
>> console setting
>> in libbsp/i386/pc386/console/console.c.
> Yes, those are the variables which I'm now poking with GDB.
>> Maybe a compile time configuration setting would be enough? You
>> could put it
>> the same place you set up the device driver tables.
>> Even if you decide you really need autodetect for some reason, it
>> would be
>> nice to have a compile time force, so that you could, for example,
>> force a
>> machine with a built in VGA adapter to use serial port for console.
> Right. That's why I had the initial expression in the if statement.
> The dynamic check takes place only
> if (BSPConsolePort == BSP_CONSOLE_PORT_CONSOLE)
> Thus, if you've set BSPConsolePort to another value (at compile time,
> or with a debugger) it will retain that vavluje.
> Eric Norum <eric.norum at usask.ca>
> Department of Electrical Engineering
> University of Saskatchewan
> Saskatoon, Canada.
> Phone: (306) 966-5394 FAX: (306) 966-5407
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
