Problem with default gateway
Vyacheslav V. Burdjanadze
wr at zelax.ru
Thu Jul 18 16:21:48 UTC 2002
> This function is called from the 'rtrequest' and
> returns address of the interface, appropriate to the
> specified gateway.
> By the default, 'ifa_ifwithroute' can't find the
> interface for the gateway from the "almost" directly connected
> network.
> But after modifying this function for always returning
> address of my eth0 interface, everything goes just fine,
> i.e. default router is assigning.
> Is this the unique decision?
This cause problems if you have more than one interface on your board.
The better solution is to take additional parameter to rtrequest - the
interface name. Then, in rtrequest , if you not able to find ifa, you
should use corresponding ifp->if_addrlist as your ifa. I'll try it soon.
- " Why do you call this software 'beta' ? "
- " Cuz it beta than nothin' ! "
