Copying from Linux
Jay Monkman jtm at smoothsmoothie.com
Fri Jul 19 17:10:30 UTC 2002
On Fri, Jul 19, 2002 at 11:54:20AM -0500, Jay Monkman wrote:
> I'll wait until I hear back from the author of the Linux one (Russell
> King), since that one is up to 25% faster.
On second thought, I might as well get you the BSD one. It's certainly
better than nothing, and if allowed, we can replace it later. I'm not
sure if the entry labels are correct for newlib, but they look right,
and just in case, I left the explicit entry code in (commented out though).
Jay Monkman	    The truth knocks on the door and you say "Go away, I'm
                    looking for the truth," and so it goes away. Puzzling.
		     - from _Zen_and_the_Art_of_Motorcycle_Maintenance_
/*	$NetBSD: memcpy.S,v 1.3 1997/11/22 03:27:12 mark Exp $	*/
 * Copyright (c) 1997 The NetBSD Foundation, Inc.
 * All rights reserved.
 * This code is derived from software contributed to The NetBSD Foundation
 * by Neil A. Carson and Mark Brinicombe
 * modification, are permitted provided that the following conditions
 * are met:
 * 1. Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * 3. All advertising materials mentioning features or use of this software
 *    must display the following acknowledgement:
 *	This product includes software developed by the NetBSD
 *	Foundation, Inc. and its contributors.
 * 4. Neither the name of The NetBSD Foundation nor the names of its
 *    contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
 * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
 * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
/* This was modified by Jay Monkman <jmonkman at smoothsmoothie.com> to
 *   save and restore r12. This is necessary for RTEMS.
#include <machine/asm.h>
.globl memcpy
memcpy:
ENTRY(memcpy)
	stmfd	sp!, {r0, r12, lr}
	bl	_memcpy
	ldmfd	sp!, {r0, r12, pc}
.globl memove
memmove:
ENTRY(memmove)
	bl	_memcpy
 * This is one fun bit of code ...
 * Some easy listening music is suggested while trying to understand this
 * code e.g. Iron Maiden
 * For anyone attempting to understand it :
 * The core code is implemented here with simple stubs for memcpy()
 * memmove() and bcopy().
 * All local labels are prefixed with Lmemcpy_
 * Following the prefix a label starting f is used in the forward copy code
 * while a label using b is used in the backwards copy code
 * The source and destination addresses determine whether a forward or
 * backward copy is performed.
 * Separate bits of code are used to deal with the following situations
 * for both the forward and backwards copy.
 * unaligned source address
 * unaligned destination address
 * Separate copy routines are used to produce an optimised result for each
 * of these cases.
 * The copy code will use LDM/STM instructions to copy up to 32 bytes at
 * a time where possible.
 * Note: r12 (aka ip) can be trashed during the function along with
 * r0-r3 although r0-r2 have defined uses i.e. src, dest, len through out.
 * Additional registers are preserved prior to use i.e. r4, r5 & lr
 * Apologies for the state of the comments ;-)
_memcpy:
ENTRY(_memcpy)
	/* Determine copy direction */
	cmp	r1, r0
	bcc	Lmemcpy_backwards
	moveq	r0, #0			/* Quick abort for len=0 */
	moveq	pc, lr
	stmdb	sp!, {r0, lr}		/* memcpy() returns dest addr */
	subs	r2, r2, #4
	blt	Lmemcpy_fl4		/* less than 4 bytes */
	ands	r12, r0, #3
	bne	Lmemcpy_fdestul		/* oh unaligned destination addr */
	ands	r12, r1, #3
	bne	Lmemcpy_fsrcul		/* oh unaligned source addr */
Lmemcpy_ft8:
	/* We have aligned source and destination */
	subs	r2, r2, #8
	blt	Lmemcpy_fl12		/* less than 12 bytes (4 from above) */
	subs	r2, r2, #0x14
	blt	Lmemcpy_fl32		/* less than 32 bytes (12 from above) */
	stmdb	sp!, {r4}		/* borrow r4 */
	/* blat 32 bytes at a time */
	/* XXX for really big copies perhaps we should use more registers */
Lmemcpy_floop32:
	ldmia	r1!, {r3, r4, r12, lr}
	stmia	r0!, {r3, r4, r12, lr}
	subs	r2, r2, #0x20
	bge	Lmemcpy_floop32
	cmn	r2, #0x10
	ldmgeia	r1!, {r3, r4, r12, lr}	/* blat a remaining 16 bytes */
	stmgeia	r0!, {r3, r4, r12, lr}
	subge	r2, r2, #0x10
	ldmia	sp!, {r4}		/* return r4 */
Lmemcpy_fl32:
	adds	r2, r2, #0x14
	/* blat 12 bytes at a time */
Lmemcpy_floop12:
	ldmgeia	r1!, {r3, r12, lr}
	stmgeia	r0!, {r3, r12, lr}
	subges	r2, r2, #0x0c
	bge	Lmemcpy_floop12
Lmemcpy_fl12:
	adds	r2, r2, #8
	blt	Lmemcpy_fl4
	subs	r2, r2, #4
	ldrlt	r3, [r1], #4
	strlt	r3, [r0], #4
	ldmgeia	r1!, {r3, r12}
	stmgeia	r0!, {r3, r12}
	subge	r2, r2, #4
Lmemcpy_fl4:
	/* less than 4 bytes to go */
	adds	r2, r2, #4
	ldmeqia	sp!, {r0, pc}		/* done */
	/* copy the crud byte at a time */
	cmp	r2, #2
	ldrb	r3, [r1], #1
	strb	r3, [r0], #1
	ldrgeb	r3, [r1], #1
	strgeb	r3, [r0], #1
	ldrgtb	r3, [r1], #1
	strgtb	r3, [r0], #1
	ldmia	sp!, {r0, pc}
	/* erg - unaligned destination */
Lmemcpy_fdestul:
	rsb	r12, r12, #4
	cmp	r12, #2
	/* align destination with byte copies */
	ldrb	r3, [r1], #1
	strb	r3, [r0], #1
	ldrgeb	r3, [r1], #1
	strgeb	r3, [r0], #1
	ldrgtb	r3, [r1], #1
	strgtb	r3, [r0], #1
	subs	r2, r2, r12
	blt	Lmemcpy_fl4		/* less the 4 bytes */
	ands	r12, r1, #3
	beq	Lmemcpy_ft8		/* we have an aligned source */
	/* erg - unaligned source */
	/* This is where it gets nasty ... */
Lmemcpy_fsrcul:
	bic	r1, r1, #3
	ldr	lr, [r1], #4
	cmp	r12, #2
	bgt	Lmemcpy_fsrcul3
	beq	Lmemcpy_fsrcul2
	cmp	r2, #0x0c
	blt	Lmemcpy_fsrcul1loop4
	sub	r2, r2, #0x0c
	stmdb	sp!, {r4, r5}
Lmemcpy_fsrcul1loop16:
	mov	r3, lr, lsr #8
	ldmia	r1!, {r4, r5, r12, lr}
	orr	r3, r3, r4, lsl #24
	mov	r4, r4, lsr #8
	orr	r4, r4, r5, lsl #24
	mov	r5, r5, lsr #8
	orr	r5, r5, r12, lsl #24
	mov	r12, r12, lsr #8
	orr	r12, r12, lr, lsl #24
	stmia	r0!, {r3-r5, r12}
	subs	r2, r2, #0x10
	bge	Lmemcpy_fsrcul1loop16
	ldmia	sp!, {r4, r5}
	adds	r2, r2, #0x0c
	blt	Lmemcpy_fsrcul1l4
Lmemcpy_fsrcul1loop4:
	mov	r12, lr, lsr #8
	ldr	lr, [r1], #4
	str	r12, [r0], #4
	subs	r2, r2, #4
	bge	Lmemcpy_fsrcul1loop4
Lmemcpy_fsrcul1l4:
	sub	r1, r1, #3
	b	Lmemcpy_fl4
Lmemcpy_fsrcul2:
	cmp	r2, #0x0c
	blt	Lmemcpy_fsrcul2loop4
	sub	r2, r2, #0x0c
	stmdb	sp!, {r4, r5}
Lmemcpy_fsrcul2loop16:
	mov	r3, lr, lsr #16
	orr	r3, r3, r4, lsl #16
	mov	r4, r4, lsr #16
	orr	r4, r4, r5, lsl #16
	mov	r5, r5, lsr #16
	orr	r5, r5, r12, lsl #16
	mov	r12, r12, lsr #16
	orr	r12, r12, lr, lsl #16
	subs	r2, r2, #0x10
	bge	Lmemcpy_fsrcul2loop16
	ldmia	sp!, {r4, r5}
	adds	r2, r2, #0x0c
	blt	Lmemcpy_fsrcul2l4
Lmemcpy_fsrcul2loop4:
	mov	r12, lr, lsr #16
	ldr	lr, [r1], #4
	str	r12, [r0], #4
	subs	r2, r2, #4
	bge	Lmemcpy_fsrcul2loop4
Lmemcpy_fsrcul2l4:
	sub	r1, r1, #2
	b	Lmemcpy_fl4
Lmemcpy_fsrcul3:
	cmp	r2, #0x0c
	blt	Lmemcpy_fsrcul3loop4
	sub	r2, r2, #0x0c
	stmdb	sp!, {r4, r5}
Lmemcpy_fsrcul3loop16:
	mov	r3, lr, lsr #24
	orr	r3, r3, r4, lsl #8
	mov	r4, r4, lsr #24
	orr	r4, r4, r5, lsl #8
	mov	r5, r5, lsr #24
	orr	r5, r5, r12, lsl #8
	mov	r12, r12, lsr #24
	orr	r12, r12, lr, lsl #8
	subs	r2, r2, #0x10
	bge	Lmemcpy_fsrcul3loop16
	ldmia	sp!, {r4, r5}
	adds	r2, r2, #0x0c
	blt	Lmemcpy_fsrcul3l4
Lmemcpy_fsrcul3loop4:
	mov	r12, lr, lsr #24
	ldr	lr, [r1], #4
	str	r12, [r0], #4
	subs	r2, r2, #4
	bge	Lmemcpy_fsrcul3loop4
Lmemcpy_fsrcul3l4:
	sub	r1, r1, #1
	b	Lmemcpy_fl4
Lmemcpy_backwards:
	add	r1, r1, r2
	add	r0, r0, r2
	subs	r2, r2, #4
	blt	Lmemcpy_bl4		/* less than 4 bytes */
	ands	r12, r0, #3
	bne	Lmemcpy_bdestul		/* oh unaligned destination addr */
	ands	r12, r1, #3
	bne	Lmemcpy_bsrcul		/* oh unaligned source addr */
Lmemcpy_bt8:
	subs	r2, r2, #8
	blt	Lmemcpy_bl12		/* less than 12 bytes (4 from above) */
	stmdb	sp!, {r4, lr}
	subs	r2, r2, #0x14		/* less than 32 bytes (12 from above) */
	blt	Lmemcpy_bl32
Lmemcpy_bloop32:
	ldmdb	r1!, {r3, r4, r12, lr}
	stmdb	r0!, {r3, r4, r12, lr}
	subs	r2, r2, #0x20
	bge	Lmemcpy_bloop32
Lmemcpy_bl32:
	cmn	r2, #0x10
	ldmgedb	r1!, {r3, r4, r12, lr}	/* blat a remaining 16 bytes */
	stmgedb	r0!, {r3, r4, r12, lr}
	subge	r2, r2, #0x10
	adds	r2, r2, #0x14
	ldmgedb	r1!, {r3, r12, lr}	/* blat a remaining 12 bytes */
	stmgedb	r0!, {r3, r12, lr}
	subge	r2, r2, #0x0c
	ldmia	sp!, {r4, lr}
Lmemcpy_bl12:
	adds	r2, r2, #8
	blt	Lmemcpy_bl4
	subs	r2, r2, #4
	ldrlt	r3, [r1, #-4]!
	strlt	r3, [r0, #-4]!
	ldmgedb	r1!, {r3, r12}
	stmgedb	r0!, {r3, r12}
	subge	r2, r2, #4
Lmemcpy_bl4:
	adds	r2, r2, #4
	moveq	pc, lr			/* done */
	cmp	r2, #2
	ldrb	r3, [r1, #-1]!
	strb	r3, [r0, #-1]!
	ldrgeb	r3, [r1, #-1]!
	strgeb	r3, [r0, #-1]!
	ldrgtb	r3, [r1, #-1]!
	strgtb	r3, [r0, #-1]!
	mov	pc, lr
Lmemcpy_bdestul:
	cmp	r12, #2
	ldrb	r3, [r1, #-1]!
	strb	r3, [r0, #-1]!
	subs	r2, r2, r12
	blt	Lmemcpy_bl4		/* less than 4 bytes to go */
	ands	r12, r1, #3
	beq	Lmemcpy_bt8		/* we have an aligned source */
Lmemcpy_bsrcul:
	bic	r1, r1, #3
	ldr	r3, [r1, #0]
	cmp	r12, #2
	blt	Lmemcpy_bsrcul1
	beq	Lmemcpy_bsrcul2
	cmp	r2, #0x0c
	blt	Lmemcpy_bsrcul3loop4
	sub	r2, r2, #0x0c
	stmdb	sp!, {r4, r5, lr}
Lmemcpy_bsrcul3loop16:
	mov	lr, r3, lsl #8
	ldmdb	r1!, {r3-r5, r12}
	orr	lr, lr, r12, lsr #24
	mov	r12, r12, lsl #8
	orr	r12, r12, r5, lsr #24
	mov	r5, r5, lsl #8
	orr	r5, r5, r4, lsr #24
	mov	r4, r4, lsl #8
	orr	r4, r4, r3, lsr #24
	stmdb	r0!, {r4, r5, r12, lr}
	subs	r2, r2, #0x10
	bge	Lmemcpy_bsrcul3loop16
	ldmia	sp!, {r4, r5, lr}
	adds	r2, r2, #0x0c
	blt	Lmemcpy_bsrcul3l4
Lmemcpy_bsrcul3loop4:
	mov	r12, r3, lsl #8
	ldr	r3, [r1, #-4]!
	orr	r12, r12, r3, lsr #24
	str	r12, [r0, #-4]!
	subs	r2, r2, #4
	bge	Lmemcpy_bsrcul3loop4
Lmemcpy_bsrcul3l4:
	add	r1, r1, #3
	b	Lmemcpy_bl4
Lmemcpy_bsrcul2:
	cmp	r2, #0x0c
	blt	Lmemcpy_bsrcul2loop4
	sub	r2, r2, #0x0c
Lmemcpy_bsrcul2loop16:
	mov	lr, r3, lsl #16
	orr	lr, lr, r12, lsr #16
	mov	r12, r12, lsl #16
	orr	r12, r12, r5, lsr #16
	mov	r5, r5, lsl #16
	orr	r5, r5, r4, lsr #16
	mov	r4, r4, lsl #16
	orr	r4, r4, r3, lsr #16
	subs	r2, r2, #0x10
	bge	Lmemcpy_bsrcul2loop16
	adds	r2, r2, #0x0c
	blt	Lmemcpy_bsrcul2l4
Lmemcpy_bsrcul2loop4:
	mov	r12, r3, lsl #16
	ldr	r3, [r1, #-4]!
	orr	r12, r12, r3, lsr #16
	str	r12, [r0, #-4]!
	subs	r2, r2, #4
	bge	Lmemcpy_bsrcul2loop4
Lmemcpy_bsrcul2l4:
	add	r1, r1, #2
	b	Lmemcpy_bl4
Lmemcpy_bsrcul1:
	cmp	r2, #0x0c
	blt	Lmemcpy_bsrcul1loop4
	sub	r2, r2, #0x0c
Lmemcpy_bsrcul1loop32:
	mov	lr, r3, lsl #24
	orr	lr, lr, r12, lsr #8
	mov	r12, r12, lsl #24
	orr	r12, r12, r5, lsr #8
	mov	r5, r5, lsl #24
	orr	r5, r5, r4, lsr #8
	mov	r4, r4, lsl #24
	orr	r4, r4, r3, lsr #8
	subs	r2, r2, #0x10
	bge	Lmemcpy_bsrcul1loop32
	adds	r2, r2, #0x0c
	blt	Lmemcpy_bsrcul1l4
Lmemcpy_bsrcul1loop4:
	mov	r12, r3, lsl #24
	ldr	r3, [r1, #-4]!
	orr	r12, r12, r3, lsr #8
	str	r12, [r0, #-4]!
	subs	r2, r2, #4
	bge	Lmemcpy_bsrcul1loop4
Lmemcpy_bsrcul1l4:
	add	r1, r1, #1
	b	Lmemcpy_bl4
