TFTP write() in 4.5.0 [PATCH]
Vyacheslav V. Burdjanadze wr at zelax.ru
Mon Jun 3 16:28:05 UTC 2002
This patch enables tftp write operation (at least) for rtems-4.5.0
release. This is actually slighty modifyed v1.20 if tftpDriver.c under
libnetworking/lib. I did it because I need it in my work that is based
on 4.5.0 release and I have not time to wait for next release. May be
someone got the same problems. So:
1. Get libnetworking/lib/tftpDriver.c v1.20
2. Apply following patch
--- 1/tftpDriver.c	Wed Jan 16 17:50:04 2002
+++ tftpDriver.c	Mon Jun  3 12:11:40 2002
@@ -15,6 +15,8 @@
+#define COMPAT_450
@@ -24,18 +26,26 @@
  #include <fcntl.h>
  #include <rtems/libio.h>
+#ifndef COMPAT_450
  #include <rtems/libio_.h>
  #include <rtems/seterr.h>
+#endif
  #include <sys/types.h>
  #include <sys/socket.h>
  #include <netinet/in.h>
  #include <arpa/inet.h>
  #ifdef RTEMS_TFTP_DRIVER_DEBUG
  int rtems_tftp_driver_debug = 1;
  #endif
+#ifdef COMPAT_450
+#define rtems_set_errno_and_return_minus_one(X) \
+    do {errno = X; return -1; } while( 0 );
+#endif
   * Range of UDP ports to try
@@ -756,7 +766,11 @@
      unsigned32     mode
+#ifdef COMPAT_450
+    char full_path_name[256];
+#else
      char *full_path_name;
+#endif
      char *s1;
      int err;
@@ -774,6 +788,9 @@
          new_name += len;
          s1 = "";
+#ifdef COMPAT_450
+    strncpy (full_path_name, new_name, sizeof(full_path_name));
+#else
      else {
          s1 = rtems_filesystem_current.node_access;
@@ -782,9 +799,12 @@
          return ENOMEM;
      strcpy (full_path_name, s1);
      strcat (full_path_name, new_name);
+#endif
      fixPath (full_path_name);
      err = rtems_tftp_open_worker (iop, full_path_name, flags, mode);
+#ifndef COMPAT_450
      free (full_path_name);
+#endif
      return err;
- " Why do you call this software 'beta' ? "
- " Cuz it beta than nothin' ! "
