Using partitions in (Arcnet) device drivers?
Ian Caddy
ianc at microsol.iinet.net.au
Wed Jun 26 06:55:31 UTC 2002
Hi All,
We are in the process of putting an arcnet device driver into our RTEMS
BSP for the Coldfire 5307.
By the end of it, we hope to have the Arcnet device driver supporting
both the legacy packet interface of an existing product but at the same
time putting a layer in so we can use IP over the Arcnet also.
Our Arcnet is configured to only have 256 byte packets, and we need
somewhere to put them when they are received.
We have two options available to us, the first is to get the number of
buffers required off the heap and then manage them ourselves.
The second option is to create partition for the buffers and then let
RTEMs manage the buffers for us.
We are working on the 4.5.0 release of RTEMs and I did a quick search
through the tree and no-one in the RTEMs system seems to use any
partitions. There are some used in the tests.
Is there some reason why partitions have not been used, as it looks like
exactly what we need for this device driver?
Also, just a note on the SMC91C111 Ethernet port we were doing. It is
complete now with DMA and working well, but I have been dragged off it
for some time. I still haven't managed to move it into the libchip area
but it is still on my list of things to do. I just need to make sure
the Arcnet is running also and then I will get back to it.
regards,
Ian Caddy
Microsol (Aust) Pty Ltd
Phone: (+61) 08 9473 6600
Fax: (+61) 08 9473 6699
