downloading image
root
joel at OARcorp.com
Thu Jun 6 17:33:08 UTC 2002
> Sachin K wrote:
> Hi,
> i have few questions,
> 1) How to run an RTEMS image standalone on PC if the image doesn't
> fit in a floppy? (i have tried with grub for small application & it
> works)
Is the image stripped or does it include debug information? With
debug information, even the smallest programs might not fit.
But many people use a network boot type setup.
> 2) How to debug the application using remote GDB ? ( i have gone
> through "rtems_gdb.pdf" & "rgdb_specs.pdf" still i don't know what to
> run on the remote machine ??)
You should be able to use the i386-RTEMS-gdb (note the caps) and
just follow the instructions. The debug server is included with
your application.
> these questions may be silly ... but please do reply.
They aren't silly. :)
> TIA,
> Sachin K
> Dexcel Electronics Designs (P) Ltd., Bangalore, India
joel at OARcorp.com On-Line Applications Research
