Posix tests
Jay Monkman jtm at smoothsmoothie.com
Mon Jun 24 21:23:37 UTC 2002
On Mon, Jun 24, 2002 at 02:46:16PM -0500, Joel Sherrill wrote:
> Jay Monkman wrote:
> > I can't get the Posix regression tests to run on ARM. POSIX_Init never
> > gets called. They do run on the pc386 BSP, and PowerPC simulator BSP.
> > Can anybody help?
> Set a break point on the fatal error code.  This sounds suspiciously
> like a problem in the startup code on the BSP.  What BSP is this
> actually?
I found it. I screwed up in the BSP. I'm not sure why, but I had set
the POSIX_api_configuration set to NULL.
Thanks.
Jay Monkman	    The truth knocks on the door and you say "Go away, I'm
                    looking for the truth," and so it goes away. Puzzling.
		     - from _Zen_and_the_Art_of_Motorcycle_Maintenance_
