question about modifying BSP
Thu Mar 7 18:26:45 UTC 2002
Gerald Needell wrote:
> OK - time for me to admit my complete ignorance and ask for some basic
> help. I want to make some changes to the BSP code. In particular I want
> to modify start.S - How do I do this in so I can test it in  a "local"
> framework. that is. I don't want to rebuilt rtems and replace teh
> existin start.o until I get it right. Have I missed some critical part
> of the documentation, or is this not really covered anywhere?
This is a hard file to replace outside the tree because the bsp_specs
reference it.
I have used a hack in the past where I call a single C routine
from the start.S (boot_card) and I provide that routine myself.
It can do minimal initialization of a serial port and push a few
characters out.
I only do this when starting a BSP.  For other mods, I build
usually enable maintainer mode and build from the top.  If
I have compile problems on a single file, I go down to that directory
in the build tree to do makes.
> - Thanks - Jerry
> _______________________________________________________________________
> Jerry Needell                     | Internet: jerry.needell at unh.edu
> Space Science Center/Morse Hall   | Voice: (603) 862 2732
> University Of New Hampshire       | FAX:   (603) 862 0311
> Durham, NH 03824                  |
