linux-posix
Sun Mar 10 14:37:37 UTC 2002
Peter Mueller wrote:
> Hi Joel
> is it "rtems_port_create" etc you mean? I don't find such calles in the mp tests.
No.  Look in the shmsupp directory in the bsp and see what it is doing.
> Peter
> On Sat, 09 Mar 2002 18:05:33 -0600
> > > Hi Aaron, hi Joel,
> > > do I have to consider anything special configuring rtems using the ways you suggested?
> > > Shared Memory: I assume that this requires MP support enabled?
> > Yes since right now, that is all that uses it.
>    Part 1.2Type: application/pgp-signature
