build error
Peter Mueller pmueller at decrc.abb.de
Mon Mar 11 17:02:55 UTC 2002
Hi all,
to use shared memory support between rtems/posix and linux I need to build rtems with multiprocessor support enabled.
I tried that with ss-20020215. Here I get an error while linking the "hello world" example:
fix_syscall_errno is not defined in cpu.c:1125
Now I have tried to use the latest snaphot (20020301). Whith this one I get the following error:
Making all in dosfs
make[5]: Entering directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src/dosfs'
make  all-am
make[6]: Entering directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src/dosfs'
make[6]: *** No rule to make target `msdos_unixstub.c', needed by `o-optimize/msdos_unixstub.o'.  Stop.
make[6]: Leaving directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src/dosfs'
make[5]: *** [all] Error 2
make[5]: Leaving directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src/dosfs'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/pmueller/develop/rtems-ss-20020301/build-posix/c'
make: *** [all-recursive] Error 1
In both cases I use the following configure call:
../configure --enable-cxx  --enable-multiprocessing
gcc version 2.95.4 20011006 (Debian prerelease)
GNU Make version 3.79.1
Peter
Peter Mueller                     |    ABB Research Center Germany
Wallstadterstr. 59                |    68526 Ladenburg
Tel. +49-6203-716223              |    Fax. +49-6203-716403
Mail: peter.o.mueller at de.abb.com  |    www.abb.com
