[Fwd: build error]
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Mar 11 17:08:44 UTC 2002
Hi
I am going to be out of town for a couple of days and don't have
time to look into these.
--joel
-------- Original Message --------
Subject: build error
To: rtems-users at oarcorp.com
Hi all,
to use shared memory support between rtems/posix and linux I need to
build rtems with multiprocessor support enabled.
I tried that with ss-20020215. Here I get an error while linking the
"hello world" example:
fix_syscall_errno is not defined in cpu.c:1125
Now I have tried to use the latest snaphot (20020301). Whith this one I
get the following error:
Making all in dosfs
make[5]: Entering directory
`/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src/dosfs'
make all-am
make[6]: Entering directory
make[6]: *** No rule to make target `msdos_unixstub.c', needed by
`o-optimize/msdos_unixstub.o'. Stop.
make[6]: Leaving directory
make[5]: *** [all] Error 2
make[5]: Leaving directory
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory
`/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs/src'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
`/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix/libfs'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/home/pmueller/develop/rtems-ss-20020301/build-posix/c/posix'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/pmueller/develop/rtems-ss-20020301/build-posix/c'
make: *** [all-recursive] Error 1
In both cases I use the following configure call:
../configure --enable-cxx --enable-multiprocessing
gcc version 2.95.4 20011006 (Debian prerelease)
GNU Make version 3.79.1
Peter
Peter Mueller | ABB Research Center Germany
Wallstadterstr. 59 | 68526 Ladenburg
Tel. +49-6203-716223 | Fax. +49-6203-716403
Mail: peter.o.mueller at de.abb.com | www.abb.com
