Problems with PSIM
Kiran C kiranc at tataelxsi.co.in
Wed Mar 13 10:41:07 UTC 2002
Hi,
I think u'll find a file called psim in the RTEMS source.
Basically its a shell script that creates a psim_tree file
This file contains a list of arguments to the psim:
The contents of this file :psim_tree are
/#address-cells 2
/openprom/options/oea-memory-size 18388608
You can copy the above two commands to a file and name it say
psim_tree
Later  u can either connect to the simulator from gdb
by
tar sim -f psim_tree
command or else directly invoke the simulaltor.
powerpc-rtems-run.exe -f psim_tree URAPP.EXE
This is the same as
powerpc-rtems-run.exe -o ' /#address-cells 2' -o
'/openprom/options/oea-memory-size 18388608' URAPP.EXE
Hope that helps,
Kiran.C
----- Original Message -----
From: "SMIALEK Yan" <Yan.SMIALEK at criltechnology.com>
To: <rtems-users at OARcorp.com>
Sent: Wednesday, March 13, 2002 3:56 PM
Subject: Problems with PSIM
> Hello,
> I have a problem with PSIM under GDB.
> I don't know LINUX like systems very much and in spite of some answers
that
> I found in the Mailing List, I don't understand who to configure PSIM.
> I managed to install all the tools and I compiled the HelloWorld
> application.
> But When I launch it, the following message appears :
> core_find_mapping() - access to unmaped address, attach a default map to
> handle this - addr=0x80000867 nr_bytes=0x1 processor=0x1020f590
cia=0x31148
> I have read some messages talking about "PSIM" configuration options and
> modifications in a script file, but I realy don't know how to proceed :-(
> Where do I have to make the modifications ? Which options ? Do I have to
> rebuild something ?
> I work on a PC under Windows NT
> I use CYGWIN
> My target is a POWERPC "ppcn_60x"
> Thank you very much !
> Yan
