build results for FATFS and libblock (fwd)
Eugeny S. Mints jack at oktet.ru
Tue Mar 26 09:33:29 UTC 2002
Please look at the letter Joel has sent to me about results of build of
dosfs.
Regards,
			Eugeny
---------- Forwarded message ----------
Date: Fri, 01 Mar 2002 14:18:01 -0600
To: Victor V. Vengerov <vvv at oktet.ru>
Cc: lvr at oktet.ru, jack at oktet.ru
Subject: build results for FATFS and libblock
>Hi,
>Just a note to let you know that the UNIX port does not build
>under Linux with a failure trying to build "msdos_unixstub.c".
>Also dosfs/fat.c trips a gcc code generation problem for
>the ColdFire.  Chris Johns has modified the code somewhere
>in libfs before to avoid this problem and I have emailed
>him about it.
>Other than that, RTEMS built for all targets and configurations.
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel at OARcorp.com                 On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>Support Available                (256) 722-9985
Eugeny S. Mints
OKTET Ltd.
1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
Phone: +7(812)428-4384 Fax: +7(812)327-2246
mailto:Eugeny.Mints at oktet.ru
