build results for FATFS and libblock (fwd)
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 26 14:04:03 UTC 2002
"Eugeny S. Mints" wrote:
> Please look at the letter Joel has sent to me about results of build of
> dosfs.
I think Ralf has solved the problem with the UNIX port. The dosfs is
simply disabled which is reasonable given that we really use the
UNIX system calls not RTEMS ones at this time.
The coldfire problem turned out to be the implementation of
the CPU specific swap u16 and u32 routines which used invalid
assembly for the coldfire.
> Regards,
> Eugeny
> ---------- Forwarded message ----------
> Date: Fri, 01 Mar 2002 14:18:01 -0600
> From: Joel Sherrill <joel.sherrill at OARcorp.com>
> To: Victor V. Vengerov <vvv at oktet.ru>
> Cc: lvr at oktet.ru, jack at oktet.ru
> Subject: build results for FATFS and libblock
> >Hi,
> >Just a note to let you know that the UNIX port does not build
> >under Linux with a failure trying to build "msdos_unixstub.c".
> >Also dosfs/fat.c trips a gcc code generation problem for
> >the ColdFire. Chris Johns has modified the code somewhere
> >in libfs before to avoid this problem and I have emailed
> >him about it.
> >Other than that, RTEMS built for all targets and configurations.
> >Joel Sherrill, Ph.D. Director of Research & Development
> >joel at OARcorp.com On-Line Applications Research
> >Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >Support Available (256) 722-9985
> Eugeny S. Mints
> OKTET Ltd.
> 1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
> Phone: +7(812)428-4384 Fax: +7(812)327-2246
> mailto:Eugeny.Mints at oktet.ru
