code fails if made with debug
Jerry Needell
jerry.needell at unh.edu
Wed Mar 6 13:39:41 UTC 2002
As Joel suggests, this is probably a resource issue. Unfortunately the
program is halting before it can call the Internal_error_Occurred
routing. I "think" it is a stack issue. Now my question. What is the
best way to add resources. I see that in the BSP start.S code the
constant STACK_SIZE is set to 16 * 1024. Is this the best pace to make a
change or is there some more configurable place in the RTEMS confdefs
that I should be concentrating on.
- Jerry
Joel Sherrill wrote:
> Jerry Needell wrote:
> > I am pulling whats left of my hair out tring to track this down. Perhaps
> > someone can point me in the right direction. I am using the RTEMS 4.5.1
> > pre3 relaease on an ERC32 (actually TSC695) board. I have built the
> > "normal" and VARIANT=debug versions. I am testing an application using
> > the o-optimize (make) and the o-debug (make debug) versions. The
> > o-optimize version works fine but the o-debug version crashes (processor
> > halts) before it even gets to Init. Does anyone have an idea where to
> > look for the cause.
> Set a breakpoint at _Internal_error_Occurred and see where it came from.
> I suspect a resource problem.
> > This application is fairly simple. It consists of 3 very simple tasks
> > and on ISR. I can supply lots more gory details, but I thought I'd see
> > if anyone had quick response.
> > BTW - I have had no problem using the make debug generated code on other
> > test applications so the problem is not always there for the debug
> > generated code.
> > - Thanks for any tips - Jerry
> > _______________________________________________________________________
> > Jerry Needell | Internet: jerry.needell at unh.edu
> > Space Science Center/Morse Hall | Voice: (603) 862 2732
> > University Of New Hampshire | FAX: (603) 862 0311
> > Durham, NH 03824 |
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Durham, NH 03824 |
