code fails if made with debug
Wed Mar 6 14:07:47 UTC 2002
Jerry Needell wrote:
> As Joel suggests, this is probably a resource issue. Unfortunately the
> program is halting before it can call the Internal_error_Occurred
> routing. I "think" it is a stack issue. Now my question. What is the
> best way to add resources. I see that in the BSP start.S code the
> constant STACK_SIZE is set to 16 * 1024. Is this the best pace to make a
> change or is there some more configurable place in the RTEMS confdefs
> that I should be concentrating on.
You mentioned offlist that it looked to be dying in the init thread
before calling the C++ constructors.  This tends to indicate to me
that a spurious interrupt is occuring since this interrupts are
enabled at the first context switch.  This could be explained by
HW init code that is compiled differently at low optimizations
and is touching the hardware wrong.
> - Jerry
> > > I am pulling whats left of my hair out tring to track this down. Perhaps
> > > someone can point me in the right direction. I am using the RTEMS 4.5.1
> > > pre3 relaease on an ERC32 (actually TSC695) board. I have built the
> > > "normal" and VARIANT=debug versions. I am testing an application using
> > > the o-optimize (make) and the o-debug (make debug) versions. The
> > > o-optimize version works fine but the o-debug version crashes (processor
> > > halts) before it even gets to Init. Does anyone have an idea where to
> > > look for the cause.
> > Set a breakpoint at _Internal_error_Occurred and see where it came from.
> > I suspect a resource problem.
> > >    This application is fairly simple. It consists of 3 very simple tasks
> > > and on ISR. I can supply lots more gory details, but I thought I'd see
> > > if anyone had quick response.
> > > BTW - I have had no problem using the make debug generated code on other
> > > test applications so the problem is not always there for the debug
> > > generated code.
> > > - Thanks for any tips - Jerry
> > > _______________________________________________________________________
> > > Jerry Needell                     | Internet: jerry.needell at unh.edu
> > > Space Science Center/Morse Hall   | Voice: (603) 862 2732
> > > University Of New Hampshire       | FAX:   (603) 862 0311
> > > Durham, NH 03824                  |
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > Support Available                (256) 722-9985
> Durham, NH 03824                  |
