Can one BSP support multiple memory maps?
Chris Johns cjohns at cybertec.com.au
Wed Mar 6 21:21:57 UTC 2002
Joel Sherrill wrote:
> FYI I recall some user mentioning a trick to avoid
> duplicating info between the two linker scripts.  Something
> about setting values and including a base linker script.
> Who was that?
The trick I use is in the linker command file do something like:
SECTIONS
  .text . :
  .data . :
     AT (ADDR(.text) + SIZEOF(.text))
  .bss (ADDR(.data) + SIZEOF(.data)) :
Then in the makefile use something like:
  ifdef DEBUG
  ROM_BASE=0x00000000
  else
  ROM_BASE=0xff400000
  RAM_BASE=0x00000000
  endif
  ifdef DEBUG
  ADDRESS_MAP = -Ttext $(ROM_BASE)
  else
  ADDRESS_MAP = -Ttext $(ROM_BASE) -Tdata $(RAM_BASE)
  endif
  LFLAGS := -N $(ADDRESS_MAP)
  $(LD) $(LFLAGS)
I hope you get the idea and I am sure you can change this to meet your
specific needs. I use DEBUG to switch the code between a RAM debug
memory map and the ROM memory map with the one linker script.
 Chris Johns, cjohns at cybertec.com.au
