inline functions
Gerke Kok
gerke.kok at tpa-nl.com
Fri Mar 8 08:53:59 UTC 2002
This heap thing has bothered my target as well... I postponed it by setting the heap-start at a verry alligned address. But when I now hear some other people also have problems I start to thing this might be my problem as well. Still hoping for a solution...
wkr,
Gerke
*********** REPLY SEPARATOR ***********
On 07/03/02 at 17:01 Gerald Needell wrote:
>Can somone tell me if I'm barking up the wrong tree here.
>My saga began sevearl posts back with problems using the "debug"
>version of RTEMS. In digging, I have found that my application is dying
>in when trying to release heap space. The code involved uses several
>"inline" functions (..c/src/exec/score/inline/rtems/score/heap.inl). In
>reading the gcc docs, I found that when optimization is turned off, then
>so is "inlining" so all of these functions are going in as normal code.
>My question is, is this liketly to be causing my problems? The failure
>seems to occur when the address of a heap block is calculated and it
>times up non-word aligned. I am trying to persue this in two directions.
>One, the excess stack usage by these function not being inline is
>causing the problem and I'm clobbering a pointer or two, the unoptimized
>compilation of the functions is produing a legitimate alignment problem.
> So the reason for the post is can anyone tell me if this makes any
>sense or do you have any suggestions.
>thanks - Jerry
>_______________________________________________________________________
>Jerry Needell | Internet: jerry.needell at unh.edu
>Space Science Center/Morse Hall | Voice: (603) 862 2732
>University Of New Hampshire | FAX: (603) 862 0311
>Durham, NH 03824 |
