Rtems Rebuild Remake Question
Fri Mar 8 16:43:56 UTC 2002
"Bill Butler(test)" wrote:
> I am not saying that there was a Makefile.in in the build tree. I
> explained more in detail  what I was doing the first time I wrote about
> this so I skipped some steps this time.. sorry for the confusion.
Are you using the RTEMS versions of automake/autoconf or what came
with the system?
> (In the Src tree )
> 1)touch Makefile.am
> 2) ../../../../../../bootstrap (tried running in BSP SRC directory and
> m68k SRC dir)
> 3) This does create an updated Makefile.in in the SRC directory.
> (Build tree side)
> 4) configure --target=m68k-rtems --enable-rtemsbsp="<BSP>"
> --prefix=/opt/m68k-rtems
> 5) make all
> 6) makefile.in (from the SRC tree) is then used to create a Makefile in
> the build tree. Right? When I said "copied over", this is what I was
> trying to state. Sorry for the attempted shortcut.
> Problem:
> Steps 1-5 are working fine.
> Step 6 is not happening
> If I run bootstrap (../../../../../bootstrap ) in the BSP directory on
> the SCR tree side, and then steps 4 and steps 5 ,the results is that
> step 6 does not happen !
> Update: I did get it to work (step 6) when I do a bootstrap in the root
> SRC directory (/tools/rtems-ss-2002.../) shouldn't it work if you run
> bootstrap in the BSP directory only?
Yep.  bootstrap works in any directory with a configure.ac script in it.
> About --enable-maintainer-mode. I was under the impression that this
> would
> Automatically run bootstrap on a configure. But if you did boot strap
> manually you did not need it..  I am not using --enable-maintainer-mode
> currently because someone stated it was not working for all BSP. I'm I
> incorrect?
I don't know.  I don't use it often.  When I do full builds of all
configurations, I bootstrap -c / bootstrap from the top as the
first thing.
> Ah well I will test the local bootstrap method with
> -enable-maintainer-mode on and see if that changes anything.
> Sorry for all the confusion.
No problem.
> Bill Butler
> AIPCom Inc
> 972-644-2328 x16
> bbill at tnex.com
> -----Original Message-----
> From: Ralf Corsepius [mailto:corsepiu at faw.uni-ulm.de]
> Sent: Friday, March 08, 2002 9:17 AM
> To: Joel Sherrill
> Cc: Bill Butler(test); 'Ian Caddy'; 'RTEMS Users'
> Subject: Re: Rtems Rebuild Remake Question
> Am Fre, 2002-03-08 um 15.25 schrieb Joel Sherrill:
> > > No I don't believe that the 5307 was ported over with 4.5.0, at
> least it
> > > was not in the main distrubtion.. I had to modify it.. But I was
> having
> > > trouble with the mcf5307elite, which was included.
> > > But... I got it to work now.
> > > I believe this is what I had to do to make it work. You know how
> things
> > > go.. you try several things, and retry and finally it works.. Now
> what
> > > was it that fixed it?
> > > 1st. the Makefile.in is copied over on "make all" in the build
> directory
> > > not on configure. I was unsure about this.
> > Maybe this is an English thing but I think Makefile.in's are strictly
> > generated into the source tree by automake as part of bootstrap.
> Exactly. Any Makefile.in inside of the build-directory is wrong.
> > > 2nd. I had to touch the main Makefile.am in the root directory of
> the
> > > BSP.
> This would indicate not to be using --enable-maintainer-mode.
> > > I believe this is because the build looked at the bsp directory and
> > > thought it was up to date (dependence problem?). By changing the
> Main
> > > makefile, it re-ran it which in turn copied the lower
> > > "start/Makefile.in" over from the src directory.
> Another indication of not using --enable-maintainer-mode.
> > I am wondering what really happened.  There is no dependey between the
> > top level Makefile.am and any subdirectory's Makefile.am.
> Right. There shouldn't be any.
> The dependencies span between the config.status to generate a
> Makefile.in and between the a Makefile.in and it's corresponding
> Makefile.am.
> >  It is
> > possible
> > that you tried to run bootstrap while in a directory without a
> > configure.in
> > script.  I don't recall what bootstrap does/says in that case but it
> > won't
> > generate any files.
> I don't understand what you are trying to say.
> Ralf
