Rtems Rebuild Remake Question
Aaron J. Grier aaron at frye.com
Fri Mar 8 18:38:36 UTC 2002
On Fri, Mar 08, 2002 at 10:17:30AM -0600, Bill Butler(test) wrote:
> (In the Src tree )
> 1)touch Makefile.am
> 2) ../../../../../../bootstrap (tried running in BSP SRC directory and
> m68k SRC dir)
> 3) This does create an updated Makefile.in in the SRC directory.
> (Build tree side)
> 4) configure --target=m68k-rtems --enable-rtemsbsp="<BSP>"
> --prefix=/opt/m68k-rtems
> 5) make all
> 6) makefile.in (from the SRC tree) is then used to create a Makefile in
> the build tree. Right? When I said "copied over", this is what I was
> trying to state. Sorry for the attempted shortcut.
> Problem:
> Steps 1-5 are working fine.
> Step 6 is not happening
I have seen this as well.  (re-running the top-level configure doesn't
update everything.)  one thing to try is manually re-running configure
farther down in the tree, IE
cd m68k-rtems/c/$YOURBSP/lib/libbsp/m68k/$YOURBSP
head config.status
and then run the configure line shown in config.status .
--enable-maintainer-mode is supposed to add in the missing dependencies,
but I seem to recall having the same problem...
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron at frye.com
     "In a few thousand years people will be scratching their heads
       wondering how on earth the first computer was invented and
          bootstrapped without a prior computer to do it with."
                    --  Chris Malcolm, on comp.arch
