4.5.0 GCC build problem
Glen M Cornell
cornell at gdls.com
Fri Mar 15 22:34:00 UTC 2002
Tristan Gross wrote:
> I've been going through the sequence described in "started.pdf" to
> build the cross-compiler for version 4.5.0 and everything worked fine
> up to a point. Any ideas where to start? All the patches were
> applied without any problems. target is i386 host is i686
> I've executed:
> cd tools
> mkdir b-binutils
> cd b-binutils
> ../binutils-2.9.5.0.24/configure --target=i386-rtems
> --prefix=/h/tools/rtems
> make all
> make info
> make install
d'oh! looks like I should read your message a little more carefully
before I open my mouth! Is /h/tools/rtems/bin in your path? If not,
that may be the reason.
Please avoid sending me Word or PowerPoint attachments.
See http://www.fsf.org/philosophy/no-word-attachments.html
