4.5.0 GCC build problem
Tristan Gross
tristan at omegaband.com
Fri Mar 15 23:22:34 UTC 2002
On Fri, 2002-03-15 at 16:34, Glen M Cornell wrote:
> Tristan Gross wrote:
> > I've been going through the sequence described in "started.pdf" to
> > build the cross-compiler for version 4.5.0 and everything worked fine
> > up to a point. Any ideas where to start? All the patches were
> > applied without any problems. target is i386 host is i686
> > I've executed:
> > cd tools
> > mkdir b-binutils
> > cd b-binutils
> > ../binutils-2.9.5.0.24/configure --target=i386-rtems
> > --prefix=/h/tools/rtems
> > make all
> > make info
> > make install
> d'oh! looks like I should read your message a little more carefully
> before I open my mouth! Is /h/tools/rtems/bin in your path? If not,
> that may be the reason.
Double d'oh! It's now in my path.
Thanks for the help.
Tristan
Type: application/pgp-signature
Desc: This is a digitally signed message part
URL: <http://lists.rtems.org/pipermail/users/attachments/20020315/e385ef72/attachment-0001.bin>
