NanoX was Re: RTEMS Shell
amimjf at connectfree.co.uk
Tue Mar 19 11:29:00 UTC 2002
>> Rosimildo.. do you have any advice on NanoX/MicroWindows?
>I had some examples on my site, bu they are too old. Technically,
>you do need a file system to run Nano-X, but you might need it
>as soon as you need to store "Fonts", and some configuration.
>On RTEMS, NanoX runs as a process linked along with the
>rest of the system, so there is no concept of "client" and "server".
>I personally prefer the Nano-X API, but if you have a team that
>knows the Windows API ( SDK kind ), you better of with
>MicroWindows.
>Hopefully one day, I'll find time to get my old RTEMS PC from the
>garage and update these demos, but the days are too short. :-)
I remember people having some sucess with MicroWindows in the past, maybe it was you :)
on a diffrent matter, does rtems have any drivers or awareness of the vesa framebuffer ? - i suspect that would give higher performance / lower loading on most embedded systems.
regards
Matthew J Fletcher
www.amimjf.org
