Patch/Bugfix for BOOTP in rtems-ss-20020205
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Tue Mar 19 11:41:25 UTC 2002
Hi Chris,
ok, here is a corrected verison of my patch. Thank you for
your comments!
wkr,
	Thomas.
> Thomas Doerfler wrote:
> > Hm, good question. At least it would not hurt. But the line I
> > complaint is at the start of bootpc_init, long before any
> > bootp options are processed. So at least at the first run of
> > bootpc_init, "dhcp_hostname" is definitely NULL.
> Any future runs if called could have dhcp_hostname set so we should free
> the memory. It is allocated using strdup.
> > The question is: can bootpc_init be called multiple times?
> > Normally it will only be called once after system boot, but
> > are there other situations?
> A system may have some form of redundant network configuration and so
> need to obtain a network address. This is just an example not a
> recommendation for a network design.
>  Chris Johns, cjohns at cybertec.com.au
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_key.htm
--- rtems-ss-20020205/c/src/libnetworking/nfs/bootp_subr.c	Wed Sep 19 19:30:38 2001
+++ /usr/local/projects/sandbox/zem40/rtems_patch/bootp_subr.c	Tue Mar 19 12:39:24 2002
@@ -902,12 +902,15 @@
     if (rtems_create_root_fs () < 0) {
       printf("Error creating the root filesystem.\nFile not created.\n");
       update_files = 0;
-  memset(dhcp_hostname, 0, sizeof(dhcp_hostname));
+  if (dhcp_hostname != NULL) {
+    free(dhcp_hostname);
+    dhcp_hostname = NULL;
    * Find a network interface.
   for (ifp = ifnet; ifp != 0; ifp = ifp->if_next)
     if ((ifp->if_flags &
