Patch/Bugfix for BOOTP in rtems-ss-20020205
Chris Johns cjohns at cybertec.com.au
Tue Mar 19 11:24:17 UTC 2002
Thomas Doerfler wrote:
> Hm, good question. At least it would not hurt. But the line I
> complaint is at the start of bootpc_init, long before any
> bootp options are processed. So at least at the first run of
> bootpc_init, "dhcp_hostname" is definitely NULL.
Any future runs if called could have dhcp_hostname set so we should free
the memory. It is allocated using strdup.
> The question is: can bootpc_init be called multiple times?
> Normally it will only be called once after system boot, but
> are there other situations?
A system may have some form of redundant network configuration and so
need to obtain a network address. This is just an example not a
recommendation for a network design.
 Chris Johns, cjohns at cybertec.com.au
