RTEMS Shell
Fernando RUIZ CASAS (E-mail)
fernando.ruiz at ctv.es
Wed Mar 20 10:49:55 UTC 2002
Hi.
Sorry for the delay but here my poor contribution.
You can see a very extensible multiuser shell like a msdos command line.
The rtems_telnet uses it.
In libmisc/ you have it.
A lot of commands already implemented but a very reduced performances.
You can browse the directories like unix. ls, cd, mkdir, rmdir, rm, etc...
you have a very a 'login process' give you a root/user login.
You can inspect the memory. the tasks, the cpu usage, the memory usage.
Enough for the emmbebed systems.
If you start a rtems_telned() you can to use all of this remotely.
And you can add the new command quickly
-----Mensaje original-----
De: Shawn Tan [mailto:shawn.tan at aeste.net]
Enviado el: lunes, 18 de marzo de 2002 2:42
Para: rtems-users at oarcorp.com
Asunto: RTEMS Shell
Dear ppl,
I'm still trying to understand how RTEMS works.. I've downloaded the
4.5.0 and compiled it fine.. After compilation, I get a bunch of files
in the build/BSP/samples directory. I'm built it for the LEON.. and I
tested the software with TSIM..
Now it occurs to me, that there seems to be lack of a shell.. The files
run fine.. Even the multi-thread sample runs fine.. So, this tells me
that the OS is working.. Just one problem.. there's no shell..
Is there a shell for the RTEMS??
What kind of filesystem does the RTEMS use??
What's the filesystem organization??
Can RTEMS support rom filesystem??
I plan to put in NanoX in the future.. How should I go about placing it
in and starting it up? (that's why I asked about the rom filesystem).
Just some questions..
With Metta,
Shawn Tan.
