Anyone using RTEMS on MPC8260ADS
Mike Siers
mikes at poliac.com
Thu Mar 21 15:26:44 UTC 2002
Hi Steven,
I can not help you with the MPC826x BSP but I am currently
using OpenBSD for my cross-platform development. My target
is a Motorola Coldfire and I am using the snapshot dated
2002/03/01. I have not moved to the newer snapshots yet
since they require automake 1.5 which I do not have a port
for yet. Below are my comments. I hope they help.
1) Install GNU sed (version 3.02) and ensure it is in your
path before the BSD sed.
2) Install GNU patch (version 2.5.4) and ensure it is in
your path befor the default patch program.
3) Install GNU make (version 3.79.1). Make a symbolic link
from "gmake" to "make" and ensure it is in your path before
the default make.
4) Install GNU m4 and ensure it is in your path before the
default m4. (This may not be necessary but it doesn't hurt).
5) Install following programs and anything they require:
autoconf 2.13
automake 1.4
libtool 1.3.5
Now try it out. I have successfully built the m68k tools, gdb,
and the rtems source. Also, I added an BDM loadable kernel module
driver for gdb. I sent this to the BDM maintainer so it should
be included in the latest release. I am assuming that NetBSD also
supports LKM so this driver should also work for you. If your target
supports BDM, you should be able to debug using gdb and ddd.
Good Luck
Mike Siers
> -----Original Message-----
> From: Steven Grunza [mailto:steven_grunza at ieee.org]
> Sent: Wednesday, March 20, 2002 7:16 PM
> To: rtems-users at oarcorp.com
> Subject: Anyone using RTEMS on MPC8260ADS
> Is anyone using RTEMS on a Motorola MPC826x processor or even better on
> Motorola's MPC8260ADS? I haven't found a BSP for the 826x line and I've
> heard that the MMU is rather different between the MPC860 and the
> MPC8260. I may have a loaner 8260ADS for a month or so for running some
> benchmarks and I plan to try to use RTEMS as my OS/executive. Thanks for
> any offers of help.
> I'll be developing code under either SPARC or x86 based systems running
> NetBSD (www.netbsd.org for details on NetBSD) but might not have a OCD
> (on-chip debugger) available.
Surrey Satellite Technology Limited
http://www.sstl.co.uk
The views expressed in this email are my own(isn't that reassuring?)
