IMFS question
Chris Johns cjohns at cybertec.com.au
Fri May 10 04:08:03 UTC 2002
Glen M Cornell wrote:
> Is there a utility or procedure to convert a directory of files into an
> in-memory file system?
What I have done with a m68k target is make a tar file (not compressed) of the files to serve. Then run:
   m68k-rtems-ld -r -o pages-tar.o -b binary pages.tar
linking pages-tar.o to my application. In the code do:
#include <ftpd.h>
#include <rtems/untar.h>
#include <rtems_webserver.h>
#include <rtems/monitor.h>
 * These are created by the linker when linking a binary file.
extern int _binary_pages_tar_start;
extern int _binary_pages_tar_size;
struct rtems_ftpd_configuration rtems_ftpd_configuration = {
   175,         /* FTPD task priority            */
   1024,        /* Maximum buffersize for hooks  */
   21,          /* Well-known port     */
   NULL         /* List of hooks       */
int main(int argc, char **argv)
  Untar_FromMemory ((unsigned char *) (&_binary_pages_tar_start),
                    (int) &_binary_pages_tar_size);
  rtems_initialize_webserver ();
  rtems_initialize_ftpd ();
  rtems_monitor_init (0);
  rtems_task_suspend (RTEMS_SELF);
  return 0;
  Chris Johns, cjohns at cybertec.com.au
