IMFS question
Glen M Cornell
cornell at gdls.com
Thu May 9 22:03:02 UTC 2002
Is there a utility or procedure to convert a directory of files into an
in-memory file system?
For example, if I have an embedded web server, I would want to serve up
files that are statically linked into the RTEMS kernel. I believe that
this is possible after reading the RTEMS Filesystem Design Guide, but I
found no references to examples or how to create my own IMFS other than
a pointer to base_fs.c.
thanks,
glenco
