pc386 BSP - is it still supported?
Angelo Fraietta
angelo_f at bigpond.com
Sun May 19 22:16:14 UTC 2002
The versions I am using are as Follows:
rtems-ss-20020301.tar.gz
rtems-base-binutils-2.11.2-1.i386.rpm
i386-rtems-binutils-2.11.2-1.i386.rpm
rtems-base-gcc-gcc2.95.3newlib1.9.0-3.i386.rpm
i386-rtems-gcc-gcc2.95.3newlib1.9.0-3.i386.rpm
Additionally, I am using the bit script, which generates the configure
command.
I execute the script like this:
./bit_rtems i386 pc386dx
Additionally, I have a symlink for my rtems version to RTEMS4.5.0ss
Robin Iddon wrote:
>Angelo,
>Thanks - no need to worry about the RPM's version numbers - that is what I
>am using - just downloaded yesterday.
>I still get an error compiling - I use the following configure command:
>../rtems-ss-20020301/configure --target=i386-rtems --disable-pos
>ix --disable-itron --disable-networking --enable-rtemsbsp=pc386dx
>I get the following error message from the compilation:
>i386-rtems-gcc --pipe -B../../../../../../../lib/ -B../../../../../../../pc3
>86dx/lib/ -specs
>bsp_specs -qrtems -DHAVE_CONFIG_H -DUSE_INIT_FINI -ansi -fasm -O4 -g
> -Wall -msoft-float -mno-fp-ret-in-387 -o o-optimize/sbrk.o -c
>../../../../../../../../../rtems-ss-20020301/c/src/lib/libbsp/i386/pc386/sta
>rtup/../../../shared/sbrk.c
>rtup/../../../shared/sbrk.c:27: conflicting types for `sbrk'
>/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../.
>./i386-rtems/include/sys/
>unistd.h:57: previous declaration of `sbrk'
>If you could send me your "configure" command and double check you are using
>the same snapshot release, that would be really helpful!
>Thanks,
>Robin
>----- Original Message -----
>From: Angelo Fraietta
>To: Robin Iddon
>Cc: rtems-users at oarcorp.com
>Sent: Sunday, May 19, 2002 8:09 AM
>Subject: Re: pc386 BSP - is it still supported?
>No, I mean the pre built RPMs from the OARCorp site. I'll get the version
>numbers I am using tommorrow when I start my Linux machine up.
>The pc386dx BSP was added after that release.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20020520/54319b73/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20020520/54319b73/attachment-0001.ksh>
