Problems with user-extension
Jan Suchotzki jsuchotzki at web.de
Tue May 21 14:35:24 UTC 2002
Hi,
I would like to register a task_create_extension at the system
wide, statical extension-table.
I defined the following:
rtems_extension TaskCreate (
  rtems_tcb *current_task,
  rtems_tcb *new_task
rtems_extensions_table Extensions = {
  TaskCreate,                      /* task create user extension */
I got the following error from the compiler:
 initialization to `boolean (*)(Thread_Control *, Thread_Control
*)' from `rtems_extension (*)(rtems_tcb *, rtems_tcb *)'
I found at userext.h that the task_create_extension has another
definition compared to all other extensions. But how to fix the
problem???
With kind regards...
...Jan
