unable to 'make test' after make install
Bhanu Nagendra P. bpisupat at cs.indiana.edu
Fri May 31 22:10:40 UTC 2002
After building RTEMS for pc386 BSP for i386 architecture, I am not able to
make the tests.
After running configure and making install, the documentation says running
'make test' makes the test suite. However, the corresponding makefile does
not have a target for 'test'.
I did run configure with --enable-tests option
Any thoughts?
-Bhanu
