IMFS question
Glen M Cornell cornell at gdls.com
Fri May 10 16:13:07 UTC 2002
Chris Johns wrote:
> Glen M Cornell wrote:
>> Is there a utility or procedure to convert a directory of files into
>> an in-memory file system?
> What I have done with a m68k target is make a tar file (not
> compressed) of the files to serve. Then run:
>   m68k-rtems-ld -r -o pages-tar.o -b binary pages.tar
very cool.  I've been converting files to c code, then compiling - which
could take a long time.  I use the following bourne shell function:
convert_file() {
  FILE=$1
  NAME=$2
  cat - <<EOF
 * File data for ${FILE}
static unsigned char file_${NAME}[] = {
EOF
  # Because a file may not be a text file, we can't place the
  # code in a string of bytes as characters.  Instead, we will
  # use od to print out the hexadecimal values of each character
  # as an element in an array of unsigned bytes:
  cat $FILE | /bin/od -v -t xC | cut -c9- |
    sed -e '/^[     ]*$/d' -e 's/\([0-9a-f][0-9a-f]\)/0x\1,/g'
  echo "};"
  echo ""
to essentially do the same thing as the ld trick.
However, what I'm looking to do is create the file system at compile
time to avoid any startup-time penalties associated with creating the
file system and creating/copying the directories and files.
