Adding a route
Ilya Alexeev ilya at continuum.ru
Mon May 27 16:55:58 UTC 2002
Hello Artemii,
Monday, May 27, 2002 you wrote:
ASI> Hi!
ASI> Did you tried -
ASI> rtems_bsdnet_rtrequest procedure?
ASI> You could use ioctl,
ASI> or routing socket interface too.
I have looked at rtems_bsdnet_rtrequest.
It's needed in address/mask and a gateway, but not just interface...
Can you please give me an example
how to add such record with the socket/ioctl?
ASI> On Mon, 27 May 2002, Ilya Alexeev wrote:
>> Hi all.
>> Does anyone know how to implement this command for RTEMS:
>> route add -host 192.168.10.1 eth0
>> (it's a Linux command)
>> My RTEMS' eth0 interface have address=192.168.0.1.
>> There are no problems using Linux, but
>> how to add such route in RTEMS?
>> Thanks.
>> Ilya.
