Building RTEMS problem
Davide Del Vento davide_rtems at hotmail.com
Thu May 30 13:53:36 UTC 2002
Oh, sorry!
Of course I'm using the binutils stuff (cross-compiler and so on), following
the documentation of the page:
http://www.oarcorp.com/rtems/releases/4.5.0/rtemsdoc-4.5.0/share/rtemsdoc/html/started/index.html
Bye,
;Davide
>I don't know why it is trying to do so but you can't compile
>RTEMS with the native gcc.  You need to install i386-rtems tools.
>The Linux libraries are incompatible with RTEMS and it is showing.
>Also the bit scripts are deprecated in favor of directly invoking
>configure and make although that is not the problem here.
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
