Building RTEMS problem
Davide Del Vento
davide_rtems at hotmail.com
Thu May 30 17:19:36 UTC 2002
Of course my path is set correctly ;-((
(I do -in bash- export PATH=/opt/rtems/bin/:$PATH)
But it doesn't work. And some strange things occur!
For testing purposes I play with the path and some links.
I do (in /opt/rtems/bin) "ln -s i386-rtems-gcc gcc"
and I try to configure and make WITHOUT setting the path (I was wondering
where is the point where it hangs). This way it compile!!! It use my
/opt/rtems/bin//gcc link, but the /opt/rtems is NOT in the the path!!!
It hangs on c/src/lib/libc/libio.c as you can see from the attached log
(short because second stage log and with many "nothing to do").
My make is GNU and it is 3.79.1, makeinfo 4.0
Soon I will be fool, with this stuff...
Byz,
;Davide
> > Oh, sorry!
> > Of course I'm using the binutils stuff (cross-compiler and so on),
>following
> > the documentation of the page:
>http://www.oarcorp.com/rtems/releases/4.5.0/rtemsdoc-4.5.0/share/rtemsdoc/html/started/index.html
>They may be installed but are they in your PATH? For some reason, cpu.c
>is being
>compiled by /usr/bin/gcc not i386-rtems-gcc. configure is not seeing it
>for
>whatever reason.
> > Bye,
> > ;Davide
> > >I don't know why it is trying to do so but you can't compile
> > >RTEMS with the native gcc. You need to install i386-rtems tools.
> > >The Linux libraries are incompatible with RTEMS and it is showing.
> > >Also the bit scripts are deprecated in favor of directly invoking
> > >configure and make although that is not the problem here.
> > _________________________________________________________________
> > Get your FREE download of MSN Explorer at
>http://explorer.msn.com/intl.asp.
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>Support Available (256) 722-9985
Making all in doc
make[1]: Entering directory `/home/marco/rtems/Davide/built-rtems/doc'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/marco/rtems/Davide/built-rtems/doc'
Making all in make
make[1]: Entering directory `/home/marco/rtems/Davide/built-rtems/make'
Making all in Templates
make[2]: Entering directory
`/home/marco/rtems/Davide/built-rtems/make/Templates'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory
Making all in custom
`/home/marco/rtems/Davide/built-rtems/make/custom'
Making all in compilers
`/home/marco/rtems/Davide/built-rtems/make/compilers'
make[2]: Entering directory `/home/marco/rtems/Davide/built-rtems/make'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/marco/rtems/Davide/built-rtems/make'
make[1]: Leaving directory `/home/marco/rtems/Davide/built-rtems/make'
Making all in tools
make[1]: Entering directory `/home/marco/rtems/Davide/built-rtems/tools'
Making all in build
`/home/marco/rtems/Davide/built-rtems/tools/build'
Making all in cpu
make[2]: Entering directory `/home/marco/rtems/Davide/built-rtems/tools/cpu'
Making all in generic
make[3]: Entering directory
`/home/marco/rtems/Davide/built-rtems/tools/cpu/generic'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory
make[3]: Entering directory `/home/marco/rtems/Davide/built-rtems/tools/cpu'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/marco/rtems/Davide/built-rtems/tools/cpu'
make[2]: Leaving directory `/home/marco/rtems/Davide/built-rtems/tools/cpu'
Making all in update
`/home/marco/rtems/Davide/built-rtems/tools/update'
make[2]: Entering directory `/home/marco/rtems/Davide/built-rtems/tools'
make[2]: Leaving directory `/home/marco/rtems/Davide/built-rtems/tools'
make[1]: Leaving directory `/home/marco/rtems/Davide/built-rtems/tools'
Making all in c
make[1]: Entering directory `/home/marco/rtems/Davide/built-rtems/c'
Making all in make
make[2]: Entering directory `/home/marco/rtems/Davide/built-rtems/c/make'
make[2]: Leaving directory `/home/marco/rtems/Davide/built-rtems/c/make'
Making all in .
make[2]: Entering directory `/home/marco/rtems/Davide/built-rtems/c'
make[2]: Leaving directory `/home/marco/rtems/Davide/built-rtems/c'
Making all in i386ex
make[2]: Entering directory `/home/marco/rtems/Davide/built-rtems/c/i386ex'
Making all in make
`/home/marco/rtems/Davide/built-rtems/c/i386ex/make'
make[4]: Entering directory
`/home/marco/rtems/Davide/built-rtems/c/i386ex/make/compilers'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory
`/home/marco/rtems/Davide/built-rtems/c/i386ex/make/custom'
make[4]: Nothing to be done for `all-am'.
Making all in exec
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec'
Making all in score
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score'
Making all in include
make[5]: Entering directory
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/include'
Making all in rtems
make[6]: Entering directory
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/include/rtems'
Making all in score
make[7]: Entering directory
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/include/rtems/score'
make[7]: Nothing to be done for `all'.
make[7]: Leaving directory
make[7]: Nothing to be done for `all-am'.
make[6]: Leaving directory
make[6]: Nothing to be done for `all-am'.
make[5]: Leaving directory
Making all in inline
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/inline'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/inline/rtems'
Making all in score
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/inline/rtems/score'
Making all in macros
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/macros'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/macros/rtems'
Making all in score
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/macros/rtems/score'
Making all in cpu
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/cpu'
Making all in i386
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/cpu/i386'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/cpu/i386/rtems'
Making all in score
make[8]: Entering directory
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/cpu/i386/rtems/score'
make[8]: Nothing to be done for `all'.
make[8]: Leaving directory
make[8]: Nothing to be done for `all-am'.
Making all in src
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/score/src'
make[5]: Nothing to be done for `all'.
make[5]: Nothing to be done for `all-am'.
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/include'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/include/rtems'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/include/rtems/rtems'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/inline'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/inline/rtems'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/inline/rtems/rtems'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/macros'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/macros/rtems'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/macros/rtems/rtems'
Making all in optman
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/optman'
Making all in src
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/rtems/src'
Making all in posix
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/include'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/include/rtems'
Making all in posix
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/include/rtems/posix'
Making all in sys
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/include/sys'
make[6]: Nothing to be done for `all'.
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/inline'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/inline/rtems'
Making all in posix
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/inline/rtems/posix'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/macros'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/macros/rtems'
Making all in posix
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/macros/rtems/posix'
Making all in src
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/src'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/posix/optman'
Making all in itron
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/include'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/include/rtems'
Making all in itron
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/include/rtems/itron'
Making all in itronsys
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/include/itronsys'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/inline'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/inline/rtems'
Making all in itron
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/inline/rtems/itron'
Making all in src
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/itron/src'
Making all in sapi
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/include'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/include/rtems'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/inline'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/inline/rtems'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/macros'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/macros/rtems'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/optman'
Making all in src
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/sapi/src'
Making all in wrapup
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/wrapup'
Making all in rtems
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/wrapup/rtems'
Making all in posix
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/wrapup/posix'
Making all in itron
`/home/marco/rtems/Davide/built-rtems/c/i386ex/exec/wrapup/itron'
Making all in lib
`/home/marco/rtems/Davide/built-rtems/c/i386ex/lib'
`/home/marco/rtems/Davide/built-rtems/c/i386ex/lib/include'
Making all in sys
`/home/marco/rtems/Davide/built-rtems/c/i386ex/lib/include/sys'
Making all in motorola
`/home/marco/rtems/Davide/built-rtems/c/i386ex/lib/include/motorola'
Making all in zilog
`/home/marco/rtems/Davide/built-rtems/c/i386ex/lib/include/zilog'
Making all in libc
`/home/marco/rtems/Davide/built-rtems/c/i386ex/lib/libc'
/opt/rtems/bin//gcc --pipe -B../../../../i386ex/lib/ -specs bsp_specs
-qrtems -g -Wall -ansi -fasm -c -O4 -o o-optimize/libio.o
../../../../../archive/c/src/lib/libc/libio.c
../../../../../archive/c/src/lib/libc/libio.c:111: `O_NDELAY' undeclared
here (not in a function)
../../../../../archive/c/src/lib/libc/libio.c:111: initializer element is
not constant
../../../../../archive/c/src/lib/libc/libio.c:111: (near initialization for
`status_flags_assoc[0].remote_value')
../../../../../archive/c/src/lib/libc/libio.c: In function
`rtems_libio_to_fcntl_flags':
../../../../../archive/c/src/lib/libc/libio.c:162: `O_NDELAY' undeclared
(first use in this function)
../../../../../archive/c/src/lib/libc/libio.c:162: (Each undeclared
identifier is reported only once
../../../../../archive/c/src/lib/libc/libio.c:162: for each function it
appears in.)
make[4]: *** [o-optimize/libio.o] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/marco/rtems/Davide/built-rtems/c/i386ex'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/marco/rtems/Davide/built-rtems/c'
make: *** [all-recursive] Error 1
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
