Problem building RTEMS(m68k)
Sudheesh J
sudheesh at atinav.com
Fri Nov 1 06:46:20 UTC 2002
Sorry I was a bit careless while installing the newlib. The problem was
exact as you said. Hope I succeeded in building RTEMS for m68k bsp efi332.
----- Original Message -----
From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
To: "Sudheesh J - Atinav Incorporated" <sudheesh at ATINAV.COM>
Cc: <rtems-users at oarcorp.com>
Sent: Tuesday, October 29, 2002 5:29 AM
Subject: Re: Problem building RTEMS(m68k)
> Sudheesh J - Atinav Incorporated wrote:
> > I'm happy to convey that the problem was fixed with the use of the
> > sources+rtems patches.
> What was your PATH when you used the RPMs? Could you pass the tests
> outlined in "5.4: Verifying the Operation of the Cross Toolset" online
> at:
> http://www.oarcorp.com/rtemsdoc-current/html/started/started00054.html
> > But I haven't yet succeeded in building RTEMS.
> > First, an error message said:
../../../../../../../rtems-ss-20021007/c/src/../../cpukit/posix/src/cancelru
> > n.c:55: `PTHREAD_CANCELED' undeclared (first use in this function)
> > Then I added a
> > #ifndef
> > #define pair in pthread.h
> > But still it got stuck somewhere else.
> That's a hint that the newlib patch and RTEMS version are not in sync.
> The errors below are even a stronger hint as some BSD .h files moved to
> newlib to avoid filename conflicts in the install image.
> Double check your newlib patch version.
> > m68k-rtems-gcc --pipe -isystem
./../../../dmv152/lib/include -D_COMPILING_BSD_KERNEL_ -DKERNEL -DINET -
FS -DDIAGNOSTIC -DBOOTP_COMPAT -O4 -fomit-frame-pointer -g -Wall -o
> > o-optimize/kern_subr.o -c
../../../../../../../rtems-ss-20021007/c/src/../../cpukit/libnetworking/kern
> > /kern_subr.c
> > ../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:76:
parse
> > error before `*'
warning:
> > data definition has no type or storage class
> > In file included from ../../../../../dmv152/lib/include/sys/systm.h:45,
> > from
> > /kern_subr.c:43:
> > ../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:105:
parse
> > error before `rlim_t'
> > warning: data definition has no type or storage class
> > ../../../../../dmv152/lib/include/rtems/rtems_bsdnet_internal.h:106:
parse
> > error before `fixpt_t'
> > In file included from ../../../../../dmv152/lib/include/sys/systm.h:137,
> > from
> > /kern_subr.c:43:
> > ../../../../../dmv152/lib/include/sys/libkern.h:58: parse error before
> > `qmax'
`a'
> > ../../../../../dmv152/lib/include/sys/libkern.h: In function `qmax':
> > ../../../../../dmv152/lib/include/sys/libkern.h:58: `a' undeclared
(first
> > ../../../../../dmv152/lib/include/sys/libkern.h:58: (Each undeclared
> > identifier is reported only once
> > ../../../../../dmv152/lib/include/sys/libkern.h:58: for each function it
> > appears in.)
> > ../../../../../dmv152/lib/include/sys/libkern.h:58: `b' undeclared
(first
> > ../../../../../dmv152/lib/include/sys/libkern.h:58: warning: control
reaches
> > end of non-void function
> > ../../../../../dmv152/lib/include/sys/libkern.h: At top level:
> > ../../../../../dmv152/lib/include/sys/libkern.h:59: parse error before
> > `qmin'
`a'
> > ../../../../../dmv152/lib/include/sys/libkern.h: In function `qmin':
> > ../../../../../dmv152/lib/include/sys/libkern.h:59: `a' undeclared
(first
> > ../../../../../dmv152/lib/include/sys/libkern.h:59: `b' undeclared
(first
> > ../../../../../dmv152/lib/include/sys/libkern.h:59: warning: control
reaches
> > /kern_subr.c: In function `uiomove':
> > /kern_subr.c:59: dereferencing pointer to incomplete type
> > /kern_subr.c:59: `UIO_READ' undeclared (first use in this function)
> > /kern_subr.c:59: `UIO_WRITE' undeclared (first use in this function)
> > /kern_subr.c:62: dereferencing pointer to incomplete type
> > /kern_subr.c:63: dereferencing pointer to incomplete type
> > /kern_subr.c:64: dereferencing pointer to incomplete type
> > /kern_subr.c:66: dereferencing pointer to incomplete type
> > /kern_subr.c:67: dereferencing pointer to incomplete type
> > /kern_subr.c:73: dereferencing pointer to incomplete type
> > /kern_subr.c:75: `UIO_USERSPACE' undeclared (first use in this function)
> > /kern_subr.c:76: `UIO_USERISPACE' undeclared (first use in this
function)
> > /kern_subr.c:77: dereferencing pointer to incomplete type
> > /kern_subr.c:78: dereferencing pointer to incomplete type
> > /kern_subr.c:80: dereferencing pointer to incomplete type
> > /kern_subr.c:85: `UIO_SYSSPACE' undeclared (first use in this function)
> > /kern_subr.c:86:
> > /kern_subr.c:87:
> > /kern_subr.c:89:
> > /kern_subr.c:91:
> > `UIO_NOCOPY' undeclared (first use in this function)
> > /kern_subr.c:78:
> > warning: unreachable code at beginning of switch statement
> > /kern_subr.c:94:
> > /kern_subr.c:95:
> > /kern_subr.c:96:
> > /kern_subr.c:97:
> > gmake[5]: *** [o-optimize/kern_subr.o] Error 1
> > gmake[5]: Leaving directory
> > `/root/rtems/build_m68k/m68k-rtems/c/dmv152/exec/libnetworking/kern'
> > gmake[4]: *** [all-recursive] Error 1
> > gmake[4]: Leaving directory
> > `/root/rtems/build_m68k/m68k-rtems/c/dmv152/exec/libnetworking'
> > gmake[3]: *** [all-recursive] Error 1
> > gmake[3]: Leaving directory
> > `/root/rtems/build_m68k/m68k-rtems/c/dmv152/exec'
> > gmake[2]: *** [all-recursive] Error 1
> > gmake[2]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c/dmv152'
> > gmake[1]: *** [all-recursive] Error 1
> > gmake[1]: Leaving directory `/root/rtems/build_m68k/m68k-rtems/c'
> > make: *** [all-recursive] Error 1
> > Is this some problem with the snapshot?
> > regards
> > Sudheesh
> > From: "Sudheesh J - Atinav Incorporated" <sudheesh at ATINAV.COM>
> > To: "Joel Sherrill" <joel.sherrill at OARcorp.com>
> > Sent: Tuesday, October 29, 2002 10:02 AM
> > > Sorry, I missed out that in my last mail. When I tried to verify the
> > target
> > > tool set, the invalid assembler option error(as mentioned in the
> > > documentation) occured. I had installed the target tools from RPMs.
Right
> > > now I'm trying the other way, that's using sources+ rtems patches.
> > > Do I need to apply the patches even if I installed the target
tools
> > from
> > > RPMS? I had the idea that the RPMS contain tools that are already
patched.
> > > regards
> > > Sudheesh.
> > > To: "Sudheesh J" <sudheesh at ATINAV.COM>
> > > Sent: Monday, October 28, 2002 6:48 PM
> > > > > Sudheesh J wrote:
> > > > > Hi,
> > > > > I'm new to both Makefiles and RTEMS. I found the
documentation
> > > > > on RTEMS site very helpful. I followed the steps, though had some
> > > > > glitches in btw.
> > > > > 1) While installing the m68k-gdb, got a failed dependency,
> > > > > libncurses.so.4. I had libncurses.so.5 and forced the installation
> > > > > using --nodeps.
> > > > > 2) The listing of /opt/rtems/bin after the rpm installations was
> > > > > missing the c preprocessor, m68k-rtems-cpp.
> > > > > 3) The confgure command,
> > > > > ../rtems-ss-20021007/configure --target=m68k-rtems
> > > > > --enable-rtemsbsp=efi332 \
> > > > > --disable-itron --enable-cxx --enable-tests --enable-docs
> > > > > --enable-networking
> > > > > Went alright, but make produced the following output:( relevant
parts
> > > > > only)
> > > > > Making all in cpu
> > > > > gmake[5]: Entering directory
> > > > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu'
> > > > > Making all in m68k
> > > > > gmake[6]: Entering directory
`/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score/cpu/m68k'mkdir
> > > > > o-optimize
> > > > > gcc --pipe -isystem ../../../../../.././efi332/lib/include
> > > > > -g -Wall -mcpu32 -o o-optimize/cpu.o -c
../../../../../../../../rtems-ss-20021007/c/src/../../cpukit/score/cpu/m68k/
> > > cpu.c
> > > > > ../../../../../../efi332/lib/include/rtems/score/cpu.h:23,
> > > > > from
> > > > > ../../../../../../efi332/lib/include/rtems/system.h:138,
> > > > > from
> > > cpu.c:14:
> > > > > ../../../../../../efi332/lib/include/rtems/score/m68k.h:228:2:
#error
> > > > > "Unsupported CPU model
> > > > > -- are you sure you're running a 68k compiler?"
> > > > > cc1: Invalid option `cpu32'
> > > > ^^^^^^^ There's the big hint. Now go back a few lines and notice
the
> > > > name
> > > > of the compiler. It is your native one not a m68k one. Walk
through
> > > > the items
> > > > in Chapter 5 -- "Building RTEMS" in the Getting Started manual.
http://www.oarcorp.com/rtems/doc-current/share/rtems/html/started/started000
> > > 24.html
> > > cpu.c:
> > > > > In function `_CPU_ISR_install_raw_handler':
> > > cpu.c:110:
> > > > > warning: assignment makes pointer from integer without a cast
> > > > > {standard input}: Assembler messages:
> > > > > {standard input}:344: Error: invalid character '.' in mnemonic
> > > > > gmake[6]: *** [o-optimize/cpu.o] Error 1
> > > > > gmake[6]: Leaving directory
> > > > > gmake[5]: *** [all-recursive] Error 1
> > > > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec/score'
> > > > > `/root/rtems/build_m68k/m68k-rtems/c/efi332/exec'
> > > > > `/root/rtems/build_m68k/m68k-rtems/c/efi332'
> > > > > I had exported /opt/rtems/bin in PATH, but why the script still
> > > > > complaining abt a 68k compiler?
> > > > > Is the missing m68k preprocessor causing the problem? Or is it
> > > > > because of a wrong configuration assumption that the -mcpu32 was
used?
> > > > > Expecting your comments,
> > > > > Sudheesh
> > > > Joel Sherrill, Ph.D. Director of Research & Development
> > > > joel at OARcorp.com On-Line Applications Research
> > > > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > > > Support Available (256) 722-9985
