A problem to compile RTEMS with manually makefile scripts,maybe a linking proble
张 智超
zhangzhichao_forever at hotmail.com
Tue Nov 5 14:42:05 UTC 2002
I'm a student,I want to study RTEMS.
I try to write a MakeFile manually to compile RTEMS.The compile process
succeed,then I use i386-rtems-ar command to create static lib
(libkernel,libbsp,libc,libstart)just like the auto generate scripts do,it
is also OK.
But when I build the demo(c/src/tests/samples/hello) ,gcc report:
/c/src/tests/samples/hello/init.c:31: undefined reference to `printk'.
but I can sure the printk define and implement in libbsp.a.Because the
result of command "i386-rtems-nm -s libbsp.a" contain :
printk.o:
U BSP_output_char
00000271 t Letext
00000000 t printNum
000000c4 T printk
The scripts to build the demo is:
${CC} -c -Wall -fasm -g ${INCLUDEFLAGS} init.c -o init.o
${AR} ruvs libhello.a init.o
${LD} -N -T linkcmds -Map map.txt -e _start -L./ --start-group -l hello
-lc -lkernel -lbsp -lstart --end-group init.o -o hello.elf
What's Wrong??
_________________________________________________________________
免费下载 MSN Explorer: http://explorer.msn.com/lccn/
