rtems 4.5.0 + filesystem
Oliver Wohlmuth
oliver.wohlmuth at motorola.com
Mon Nov 4 12:11:25 UTC 2002
Hi all,
I'm working with rtems 4.5.0 and tried to integrate FAT filesystem support.
When trying to build the "libblock" library, I found that it expects OS calls
(e.g. CORE_mutex_Seize()) and headerfiles (e.g. for macro _IOWR) from the
rtems snapshots.
We are running rtems 4.5.0 on a custom HW, so before porting the BSP and CPU specific
code from rtems 4.5.0 to the latest snapshot, I would like to understand how stable
the current snapshort is. By stable I mean
- are OS calls likely to be changed ?
- will future rtems snapshots require BSP or CPU specific code to be reworked or
can I just copy in the code used in the previous snapshot ?
Thanks for you help,
Oliver
