Dynamic Libraries
Chris Johns cjohns at cybertec.com.au
Fri Nov 8 21:13:18 UTC 2002
Angelo Fraietta wrote:
> I see what you are saying.
It is PR46, so the intention to allow a single memory space but it has
not happened.
> What I am currently doing is that I have the target on a DIMMPC, so
> when I want to change the code, I have to physically remove the
> DIMMPC, and plug it into the development board.
Having to move hardware like this is never good for it.
> I could get around this by writing the new file through the comm port
> to the flash disk onto the DIMMPC to replace the file that is already
> there. I could write it to a temporary file name (in case the download
> crashed for some reason), and then rename it after a complete and
> successful download (I am using GRUB on a FAT filesystem).
I tend to use this way. My reasons are not technical but relate to
configuration control. I know what the image is, how it is built, what
was tested, and what was in any specific target.
> My only concern is that it is possible that the target downloaded does
> not work and the device would come back to me to do the change physically.
This is the hard part, but I suspect this problem exists which ever way
you choose to go.
  Chris Johns, cjohns at cybertec.com.au
