building problems
Poletti Francesco
fpoletti at libero.it
Mon Nov 11 17:19:12 UTC 2002
Hy, I have this kind of problem. I'm trying to make the porting of rtems for a
arm7 architecture, I have a simulator.
This is my .cfg file
> $(LINK.c) $(AM_CFLAGS) $(AM_LDFLAGS) -o $(basename $@).obj \
> $(LINK_OBJS) $(LINK_LIBS)
> $(NM) -g -n $(basename $@).obj > $(basename $@).num
> $(SIZE) $(basename $@).obj
> $(OBJCOPY) -O binary \
> $(basename $@).obj $(basename $@).bin
> arm-rtems-objdump -d $(basename $@).obj > $(basename $@).as
> arm-rtems-objdump -x $(basename $@).obj > $(basename $@).x
> cp $(basename $@).bin $(basename $@).exe
> endef
This is a piece of my bsp_start_default:
>void bsp_start_default( void )
>{ unsigned long c = "b";
> *((volatile unsigned long*) SWARM_UART0_TXBASE) = (unsigned long )(c);
After building rtems I have:
>000089c4 <bsp_start_default>:
> 89c4: e1a0c00d mov ip, sp
> 89c8: e92ddcf0 stmdb sp!, {r4, r5, r6, r7, sl, fp, ip,
> lr, pc}
> 89cc: e3a03209 mov r3, #-1879048192 ;
> 0x90000000 89d0: e59fa108 ldr sl, [pc, #264] ; 8ae0
> <bsp_start_default+0x11c>
> 89d4: e59f7108 ldr r7, [pc, #264] ; 8ae4
> <bsp_start_default+0x120>
> 89d8: e2832a81 add r2, r3, #528384 ; 0x81000
> 89dc: e59f3104 ldr r3, [pc, #260] ; 8ae8
> <bsp_start_default+0x124>
> 89e0: e59f4104 ldr r4, [pc, #260] ; 8aec
> <bsp_start_default+0x128>
> 89e4: e5975000 ldr r5, [r7]
> 89e8: e59a6000 ldr r6, [sl]
> 89ec: e59f10fc ldr r1, [pc, #252] ; 8af0
> <bsp_start_default+0x12c>
> 89f0: e5823000 str r3, [r2]
> 8ae8: 00030390 muleq r3, r0, r3
I dont understand why when I went to write in the uart the assembler commands
is str r3,[r2] ; the r2 register have the right address but in the r3
register I found the value of the address where there is the "b" char. I
think that isn't good, but what is wrong? Probably the compilation options
but why?
