Linux distribution
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Nov 13 15:55:18 UTC 2002
Am Mit, 2002-11-13 um 15.18 schrieb Joel Sherrill:
> Sudheesh J wrote:
> > If I understood your problem, I have successfully compiled a BSP(pc386) on
> > my Redhat 7.3 box from rtems ss-20021007.
> The main OAR RTEMS machine is running RedHat 7.3 but I know that other
> maintainers use different distributions.  Ralf Corsepius is a SuSE user
Correction: Had been a SuSE-user for 8 years -- I have just switched to
using a different distribution, for reasons not related to RTEMS.
> and Eric Norum uses MacOS X.
Others use Debian ...
Basically, any Unix environment should work, esp. any Linux
distribution.
Ralf
