RTEMS configuration problems
Wulf Hofbauer
wh73 at cornell.edu
Wed Nov 13 23:17:55 UTC 2002
Hi,
while trying to build the 20021111 RTEMS snapshot, I observed
several problems with the configure scripts.
o The --program-prefix option seems to be ignored. The
configuration script invariably tries to access ($TARGET)-gcc.
The order of the --target and --program-prefix options doesn't
seem to matter.
o The environment variables CC_FOR_BUILD, CFLAGS_FOR_BUILD,
CC_FOR_HOST, CFLAGS_FOR_HOST, CC_FOR_TARGET, CFLAGS_FOR_TARGET
break configure. Example (in bash):
CFLAGS_FOR_TARGET=-dummy ($SRC)/configure
results in the configure script barfing eventually
configure: CFLAGS=-dummy: command not found.
and configure fails after that.
Am I doing something wrong here? Or is configure really that
broken?
- Wulf
