RTEMS networking (RTL 8139)
Joe Samuel
sjoe2 at yahoo.com
Tue Nov 26 03:59:49 UTC 2002
Hi Sachin,
thank you for your response. But I could know
that RTL 8139 is NE2000 compatible. When I changed the
bsp.h(#define RTEMS_BSP_NETWORK_DRIVER_NAME
BSP_NE2000_NETWORK_DRIVER_NAME), the initialization
didn't hang, but I got the following messages:
Network device 'ne1' <00:D0:09:57:86:23> initialized
on port 0xC000, irq 5
Can't bring ne1 up: Too many open files on system
Can't set default roots: No such process
No routes!
Create socket
RTEMS: Can't create socket
These messages give me some hope that there is a
workaround using the RTL network card itself.
I'm posting this to the RTEMS group also. Can anyone
suggest a solution?
BTw, is the address in the first messge supposed to be
my mac address?, but ifconfig return a different
address- 00:E0:18:37:3E:86 .
regards,
Joe
--- Sachin K <sachin at dexceldesigns.com> wrote: >
----- Original Message -----
> From: "Joe Samuel" <sjoe2 at yahoo.com>
> To: "Sachin K" <sachin at dexceldesigns.com>
> Sent: Monday, November 25, 2002 5:29 PM
> Subject: Re: RTEMS networking (RTL 8139)
> > Hi Sachin,
> > thank you for your quick response. I'm using RTL
> > 8139 NIC.
> ( same card which i was using. ;) )
> > I think I should look for another NIC right?
> yes.
> try for winbond NIC.
> > Joe
> > > Sent: Monday, November 25, 2002 12:00 PM
> > > Subject: RTEMS networking (RTL 8139)
> > > > Hi Sachin,
> > > Hi Samuel,
> > > > I'm an undergradute experimenting with
> RTEMS
> > > as
> > > > part of my research project. I also faced the
> same
> > > > problem described by you here:
http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2002/july/msg00053
> > > .html
> > > > Could you please let me know if you've found
> any
> > > > work arounds?
> > > first check which type of ethernet card you
> have,
> > > because RTEMS currently
> > > supports only NE2000, dec compatible ethernet
> > > devices.
> > > if you have the network card which is compatible
> > > with the above mentioned
> > > chipset, modify the attached network config file
> > > according to your network
> > > setings and use it in your application.
> > > > thank you in advance.
> > > > Joe
> > > Sachin.K
> > > ATTACHMENT part 2 application/octet-stream
> > name=networkconfig.h
> > > Dexcel Electronics Designs (P) Ltd., Bangalore,
> > > India
> > __________________________________________________
> > Do You Yahoo!?
> > Everything you'll ever need on one web page
> > from News and Sport to Email and Music Charts
> > http://uk.my.yahoo.com
> India
Do You Yahoo!?
