bdm error
Brett Swimley
brett.swimley at aedinc.net
Fri Nov 29 23:14:13 UTC 2002
Aaron -
Did you ever get a patch put together for this? I tried applying the 5.0
cybertec patch using gdb-5.2.1 and am now getting segmentation faults.
Regards,
Brett Swimley
Sr. Design Engineer
Advanced Electronic Designs, Inc.
ph: 406-585-8892
fax: 406-585-8893
www.aedinc.net
> -----Original Message-----
> From: Aaron J. Grier [mailto:aaron at frye.com]
> Sent: Sunday, July 14, 2002 5:07 PM
> To: rtems-users at oarcorp.com
> Subject: Re: bdm error
> On Fri, Jul 12, 2002 at 02:49:53PM -0400, D. Peter Siddons wrote:
> > OK, so my gdb problem was due to the fact that I compiled the code
> > using gcc-3.1 instead of gcc-2.95, and was debugging with
> gdb-5.0. If I
> > open the file with gdb-5.2 then there are no complaints. Is
> there a bdm
> > patch for gdb-5.2?
> I started with the cybertec gdb 5.0 patch, and hand-applied the
> rejects. seems to work. give me a couple days and I could
> probably get
> a patch together, although I imagine it'd be easier for Chris Johns to
> do that. ;)
> Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
